Tribocharging in Fluent?
Old   August 12, 2010, 16:11
Default Tribocharging in Fluent?
Ray Munoz
Fluent_user is on a distinguished road
I am new to Fluent. I hope I don't leave anything out. Any help is appreciated.
I want to use Fluent to do a simulation of a tribocharging paint dispenser.
[A tribocharging paint dispenser uses pressurized gas to force dry particles through a dispenser tube. These solid particles acquire an electric charge through friction as they collide with the dispenser tube's wall, and they are sprayed to paint an object of opposite charge.]
The charge on the paint particles is affected by the number of collisions that occur on each particle as they travel down the tube.
-Does Fluent account for this effect?
-If not, does it track particle collisions, so that it could be incorporated into a UDF?
-And would a UDF be able to be created that would charge the particles as they travel down the inside of the tube, without having to change the collision or wall reflection calculations that Fluent already does?
Thanks in advance!
Ray
Fluent_user is offline   Reply With Quote
charge, collision, count, particle, tribocharging
Stopping a Fluent batch job AND saving the data! Possible? Volker Pawlik FLUENT 13 December 28, 2020 04:16
A Problem of Fluent Interpreted UDF: parse error knight Fluent UDF and Scheme Programming 25 August 16, 2018 10:26
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
Compared MRFSimpleFoam and Fluent in a centrifugal pump! renyun0511 OpenFOAM Running, Solving & CFD 8 July 6, 2010 06:24
Problems in lauching FLUENT Lourival FLUENT 3 January 16, 2008 16:48
