zip saving case&data
Old   November 25, 2009, 08:02
Default zip saving case&data
Jouke de Baar
jack1980 is on a distinguished road
If I'm not mistaken, it is possible to save case&data in zip or similar format to save disk space. Only I can't remember how to do this?
Thanks!
jack1980 is offline   Reply With Quote
Old   November 26, 2009, 01:03
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
/file/write-case-data/
enter the name you want with .cas.gz as extension
for instance:
/file/write-case-data/blabla.cas.gz
(it will write blabla.cas.gz & blabla.dat.gz)
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   November 27, 2009, 09:04
Jouke de Baar
That worked fine. Thanks!
Saving Fluent Surface Monitor Output File fossu15a Main CFD Forum 1 November 12, 2009 07:10
Saving Structured Multi-block mesh using ICEM CFD sachinspande ANSYS Meshing & Geometry 1 September 17, 2009 14:24
PB: Saving mass fraction of species on two points with an udf biget.a FLUENT 2 July 23, 2009 03:06
Saving scalar data into a user file Julie Siemens 5 October 26, 2004 01:43
File saving problem Pravesh kumar FLUENT 2 November 24, 2002 01:21
