Boundary Conditions for a Venturi in Gambit
Old   December 11, 2009, 14:24
Default Boundary Conditions for a Venturi in Gambit
KAWICGB is on a distinguished road
I need help assigning boundary conditions for a venturi I have 3-D modeled and meshed in Gambit. My known is the velocity at the inlet. I would like to find the pressure differential between the inlet and the throat and between the inlet and the outlet.
How I modeled the venturi:
-I modeled the venturi by inserting points in the following configuration
-I then connected the points to form lines
______ .........._____
| ........\_____/...... |
|_________________|
-From here I used the "Wireframe" function to connect the lines to form 1 face. Then I revolved the face to get a single solid
........___P1__.............. __P3__
.......|........... \__P2__/........... |
V -> |..................................... |
.......|............. ______............|
.......|_______/ ..........\______|
I have the 1st vertical face assigned as the velocity inlet. I have the horizontals and diagonals assigned as walls.
How do I assign the boundary conditions to get P1, P2, and P3
Thanks in advance!
KAWICGB is offline   Reply With Quote
Old   December 13, 2009, 17:18
JT.Q
jiangtao167 is on a distinguished road
venturi tube is used to obtain the velocity of flow. actually the velociy in normal direction to the axis at p is zero,so i think wall with velocity equal inlet velocity for p1&p3 is suitable,and the bc. at p2 is wall with velocity caculated by using continuity eq.
u can also try symmetry BC. which is identical with moving wall mathematically
but i have a question how you kown the inlet velocity of a venturi tube
jiangtao167 is offline   Reply With Quote
Old   December 13, 2009, 17:37
I am designing a venturi that will be used to measure the volumetric flow rate. The differential pressure will be monitored to insure the correct inlet velocity and volumetric flow rate. I've done the calculations, but now I want to simulate it and verify my work. I also want to look at the pressure regain from P2 to P3.
Old   December 15, 2009, 04:35
Default venturi
Kumar
KumarP is on a distinguished road
Hi
I think its better to use cylinder and frustum for creating the venturi (top down approach), unless u are particular about the bottom up approach. To get the pressure differential, create isosurfaces and find the static pressure difference. Hope this helps
KumarP is offline   Reply With Quote
Impinging Jet Boundary Conditions Anindya Main CFD Forum 25 February 27, 2016 12:58
Pressure boundary conditions Lionel S. Main CFD Forum 1 August 24, 2007 18:03
Boundary conditions :gambit marimuthu FLUENT 0 March 26, 2005 06:15
periodic boundary conditions in GAMBIT lavan FLUENT 1 February 23, 2005 18:11
A problem about setting boundary conditions lyang Main CFD Forum 0 September 19, 1999 18:29
