December 13, 2009, 08:33 |
Fluent 12 k-w SST turbulence model
Hi everyone,
I am using the k-w SST turbulence model to predict unsteady flow of a NACA0012 airfoil pitching at a fixed rate. I am trying to understand how this turbulence model toggles between resolving the viscous sublayer and using a wall function. Ive done a bit of searching around here and it seems that there should be a radio button that toggles transitional flow on/off but I do not see it at all in this version of Fluent 12. There is one radio button in the viscous model box that says low-Re correction, which according to the manual says should be on when resolving the sublayer, but dosent give a definite explaination as to how the model toggles between the two modes. Does anybody have any idea. And also, how does the accuracy of your solution compare when using a wall function vs resolving all the way to the viscous sublayer? Thank you for your help in advance. |
Seeking Macroscopic Particle Model in Fluent | bzhang7 | FLUENT | 3 | June 25, 2022 17:54 |
KOmega Turbulence model from wwwopenFOAMWikinet | philippose | OpenFOAM Running, Solving & CFD | 30 | August 4, 2010 10:26 |
Reynolds Stress model in CFX vs Fluent | Tim | CFX | 1 | October 7, 2009 06:19 |
two turbulence model in fluent | duaiduaihu | FLUENT | 1 | August 26, 2009 19:39 |
Fan heater model: what turbulence source to use? | andy20 | Main CFD Forum | 0 | March 2, 2008 12:46 |
