December 15, 2009, 09:14 |
About Transient Table
Hassan
Hi
I've a problem about transient table that I input in FLUENT. I've created data type PROF << I think I do it right. The question is How should I know that this transient table data is read in FLUENT correctly. How can I check it? Wait for your help thanks |
July 29, 2019, 16:37 |
Abdullah Tariq
Rep Power: 8 |
Hi, I am also trying to use a transient tables to apply my boundary condition. However when I type in the following commands into the ansys console
file /file>read-transient-table transient-table file name [] (insert name) ANSYS displays the error shown below. I made file on wordpad using the correct format and saved with txt extension. I saved the file to my desktop. Can you help me with this? Error: File "insert name" not found! Error Object: #f |
July 29, 2019, 20:10 |
Svetlana Tkachenko
Make sure your file is in the same directory as your fluent simulation. When prompted with '(insert name)', type the name of your file after it, and then press enter. Does it work then?
July 30, 2019, 06:30 |
Abdullah Tariq
Rep Power: 8 |
Hi Svetlana I have done as you have asked and saved the file in the same directory that my fluent file is saved in. However, ansys still cannot find the file. Any toughts on how I can resolve this issue? also does the transient table have to be saved as text document (.txt) extension?
July 30, 2019, 07:00 |
Svetlana Tkachenko
I would like to see a screenshot of the error message. Your command and your input should also be visible on the image. Please attach a screenshot with your next reply?.
August 10, 2021, 01:23 |
#6 | |
When you launch fluent, in the GUI there is General Options> Working Directory Here set the path to a desired directory and put that .txt file in that directory. Then fluent will be able to see this file and will be able to load. |
transient simulation of a rotating rectangle | icesniffer | CFX | 1 | August 8, 2009 07:25 |
transient results chart or table | haconk | CFX | 1 | May 6, 2009 02:49 |
Table Manipulation | furkan | Siemens | 0 | April 4, 2006 10:23 |
transient results in table viewer | Andrew Fine | CFX | 2 | December 15, 2005 23:39 |
Transient user input table | Bart | Siemens | 0 | January 10, 2005 01:27 |
