Debug source terms
Old   December 28, 2009, 07:25
Smile Debug source terms
qiang xia
alanlove is on a distinguished road
Hi,everyone
I am writing a marco of DEFINE_SOURCE as followings:
DEFINE_SOURCE(mass_source,c, t, dS, eqn)
real source_mass;
if (C_T(c,t)>800.0)
source_mass=Density*PI*area*root/C_VOLUME(c,t);
dS[eqn]=0.0;
else
dS[eqn]=source_mass=0.0;
return source_mass;
My problem is: In order to validate my codes, How can I get the value of source_mass?Any ideas,thank u very much.
alanlove is offline   Reply With Quote
Old   December 28, 2009, 21:12
Nan Zhang
nonyear is on a distinguished road
Send a message via MSN to nonyear
you can do that
(1) Use Messsage function (if the mesh file is small)
Add
Message(" source_mass = %g\n", source_mass);
before
return source_mass;
then you can get the message
(2) Through a UDM(if the mesh file is big)
define a UDM
then add
C_UDMI(c,t, 0)=source_mass;
before
return source_mass;
then you can get the message through display the coutour
nonyear is offline   Reply With Quote
Old   December 29, 2009, 06:04
qiang xia
Big Thanks
Old   December 29, 2009, 06:24
Nan Zhang
you are welcome.
Using source terms jsm Main CFD Forum 4 August 20, 2009 06:44
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
UDF Scalar Code: HT 1 Greg Perkins FLUENT 8 October 20, 2000 12:40
