Interpolation values in nodes and cells
Old   April 27, 2010, 09:20
Default Interpolation values in nodes and cells
mrestrepo30 is on a distinguished road
I am interpolating the values of a simulation into a new mesh using the Interpolation function in FLUENT. Then, I'm checking the interpolation using a UDF that checks the velocity values of the cells (using C_U, C_V, C_W). However, this values appear as zero, even though I know there are velocity values on the nodes because they appear when I plot velocity vectors and contours.
Does anyone know why I'm not getting the values in the cell? or if there's a way to get the node velocity values so I can check my interpolation results with the original solution?
Thanks!
mrestrepo30 is offline   Reply With Quote
cell, interpolation, node, velocity
Scale-Up Study in Parallel Processing with OpenFoam sahm OpenFOAM 10 April 26, 2010 17:37
total number of cells changes !!!! Zeitistgeld FLUENT 0 October 10, 2005 01:49
export nodes, cells and heat transfer coefficients Ademar Cardoso FLUENT 0 September 13, 2005 17:22
meshing F1 front wing Steve FLUENT 0 April 17, 2003 12:37
UDF for looping over nodes in cells. Malcolm Wallace FLUENT 3 July 3, 2000 09:22
