December 28, 2009, 07:25 |
Debug source terms
qiang xia
Hi,everyone
I am writing a marco of DEFINE_SOURCE as followings: DEFINE_SOURCE(mass_source,c, t, dS, eqn) { real source_mass; if (C_T(c,t)>800.0) { source_mass=Density*PI*area*root/C_VOLUME(c,t); dS[eqn]=0.0; } else dS[eqn]=source_mass=0.0; return source_mass; } My problem is: In order to validate my codes, How can I get the value of source_mass?Any ideas,thank u very much. |
December 28, 2009, 21:12 |
you can do that
(1) Use Messsage function (if the mesh file is small) Add Message(" source_mass = %g\n", source_mass); before return source_mass; then you can get the message (2) Through a UDM(if the mesh file is big) define a UDM then add C_UDMI(c,t, 0)=source_mass; before return source_mass; then you can get the message through display the coutour |
December 29, 2009, 06:04 |
qiang xia
Big Thanks
December 29, 2009, 06:24 |
you are welcome.
Using source terms | jsm | Main CFD Forum | 4 | August 20, 2009 06:44 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 01:24 |
UDF Scalar Code: HT 1 | Greg Perkins | FLUENT | 8 | October 20, 2000 12:40 |
