Reference Values for Air-Foils with high Angle-of-Attack?
Old   January 9, 2010, 11:11
Default Reference Values for Air-Foils with high Angle-of-Attack?
hornig is on a distinguished road
hi,
I'm still not 100% sure, whether or not I'm setting up the reference values right.
when I have an air-foil with a high angle of attack (eg. 30°) what do i have to put in fo area, length and depth?
I'm working with a 2D model and for small angles I take the chord line from nose to tail as the length. and when I want to get the drag properties, i will put in the area normal to the flow.
when I want to get the lift properties I will put in the area parallel to the flow (not the wet surface area, only the projected area).
as far as I know the depth can be 1 because all properties are calculated for one unit and that's also one (in my case) meter.
but when I calculate both properties for x and y / drag and lift and calculate the resulting vector for this (x^2+y^2)^0.5 they aren't near to the values given in references.
does anyone know what I'm doing wrong?
Thank you in advance,
Andreas
hornig is offline   Reply With Quote
drag coefficient, lift coefficient, reference-values
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 12:02
Windows Installation BugsComments on Petrbs patch brooksmoses OpenFOAM Installation 48 April 16, 2006 00:20
High Angle of Attack w0er Main CFD Forum 3 March 8, 2005 11:05
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
