XY Plot
Hi I have just started learning fluent through example 2d cylinder in XY plane. I modified as rotating cylinder by giving rotational motion. I want to get an XY plot between azimuthal velocity versus x distance. How can i get it? Z axis is not working in 2d mode seems, will it give any data related to z-axis? If so my assumption of cylinder rotating about z axis is true (the point of rotation i gave (0,0))?
Thanks in anticipation |
Go to 'Plot' in Fluent's tabs. You will see 'XY Plot'. A window would appear and there,you can choose the parameter for Y ordinate and the 'Surfaces' you want to evaluate.
