compute from
Old   January 14, 2010, 13:32
Default compute from
sai ram
sairam is on a distinguished road
hello everybody
i have a bunch of problems in fluent before stimulaion n after stimulation it follows as this way
1) i have four inlets for a micromixer n i am unable to know wat shud i keep in the "compute from" in "initialize" shud i select "all zones" or shud i select some inlet
2) i'm getting reverse flow when i stimulate the model, i dont no wats de reason can any one suggest me anything regarding this, i have tried outflow at output too.
3) i'm actual dealing with species mixing n mi aim is to know wheather the fluids are mixing in proper ratio or not, i hav no clue regading can any one help me thanx in advance
sairam is offline   Reply With Quote
Old   January 14, 2010, 20:27
herntan's Avatar
YH Tan
herntan is on a distinguished road
Initialize value is not important in steady simulation unless u got divergence.
compute from is also not important unless u got divergence.
As long as ur simulation converge, u are good.
I have no idea on the reverse flow, maybe its cause by the front inlet blocking it from flowing out.
species mixing can be check via species contour plot. The color of the contour can be mass fraction , molar fraction and more... check out on that one.
Herntan,
Add Reputation if I am right
herntan is offline   Reply With Quote
Old   January 15, 2010, 11:49
Default thanx dude
sai ram
thanx herntan for ur reply
i think u r right because of front intel there is reverse flow, i will try to increase the velocity of back inlet so it may work
for species mixing the picture gives a nice idea n de way de fluids are mixing
wat i'm actually stuck here is wats de mass fraction of output of each fluid species, when u see this picture very little is at outflow which dnt make any sence, can u please help me in this if u hav any info..
Old   January 16, 2010, 01:11
Default time step
Achyut Takalkar
achy7pch is on a distinguished road
your problem is of steady or unsteady state. if unsteady,what is the time step u have taken for simulation? i did face that problem i reduced my time step and it did work.
achy7pch is offline   Reply With Quote
Old   January 17, 2010, 21:14
herntan's Avatar
YH Tan
if u have 2 species of fluid mixed, its very hard to estimate their mass fraction.
I cannot understand what u mean by doesn't make sense.
Keep in mind that, mass fraction is the ratio of MASS for species 1 and species 2.
Herntan,
Old   January 19, 2010, 12:04
sai ram
its a steady flow
Old   January 19, 2010, 12:08
sai ram
wat i'm willing to tell is if i sum all the mass fractions of each species it shud be 1. but in this case its not coming to one
How do I compute the normal vector to a surface with FEM Vasilis Main CFD Forum 3 July 31, 2009 07:59
To compute Average flowfield with oodles flying OpenFOAM Running, Solving & CFD 3 May 5, 2009 08:46
How to compute liquid volume of the NOT whole domain snak OpenFOAM Post-Processing 4 June 25, 2008 07:34
How to compute an average slip velocity using DPM thomas FLUENT 0 February 9, 2004 08:17
about use macro to compute torque in TASCflow lancy CFX 0 June 10, 2003 06:19
