natural convection induced by radiation. large temperature difference!
Old   February 3, 2010, 11:57
Default natural convection induced by radiation. large temperature difference!
uncle_salty is on a distinguished road
I am having trouble with a natural convection problem in which there is a large temperature difference. The temperature difference is so large that the boussinesq model is not valid. when i turn on gravity and use a temperature dependent density function, FLUENT responds with a floating point error because my solution is diverging.
does anyone know how to fix this?
if it helps, here is a description of the system...
a vertical rectangular cavity filled with air where one wall is radiating a 5kW/m2 heat flux. I want to find the velocity of the air at the top and bottom of the cavity, as well as the temperature difference in the air.
thanks for any help in advance.
uncle_salty is offline   Reply With Quote
boussinesq, natural convection, radiation
Radiative heat transfer with natural convection inside a square cavity msarkar OpenFOAM 1 January 11, 2010 22:21
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Natural convection Jozef Main CFD Forum 9 May 16, 2007 23:56
Help! mass loss in close natural convection asarum FLUENT 1 March 2, 2005 04:49
Natural convection at a cube Michael Main CFD Forum 6 June 25, 1999 10:39
