DO radiation
Hy everybody.
I am simulating reacting flow (gas phase) through a chamber. The reaction is highly exothermic and the walls of the chamber are watercooled. I use DO radiation model. I am little bit confused about the coefficient. :o How much should I set for the coefficients and where? :confused: Should I set the Boundary Conditions/Wall/Thermal/Radiation. Here I can set the temperature but what else? And how much are these? And/Or... What should I set at the Materials/"my solid media" panel. There is also absorption and refractive index and so on. These coefficients also exist on the flowing material option. What should I set and where can I get these coefficient for my materials? Thanks in advance, Laci |
Other parameters should be determined due to your material, such as absorption coefficient, scatering coefficient and refractive index. Maybe you could go to see the FLUENT help documents.
Best Wishes. |
I figured out what I should adjust. Could you or anybody else send me a source for absorption coefficients? Thanks in advance, Laci |
