February 9, 2010, 02:05 |
multiphase heterogeneous reaction definition
chétan
Rep Power: 16 |
Hello everyone
It is mentioned in UDF manual while defining DEFINE_HET_RXN_RATE macro, "The bulk phase can participate in the reaction if the phase does not have any species ( phase has fluid material instead of mixture material)". I am trying to model reaction between air (primary phase) and carbon (secondary phase) to yield CO (of primary phase) with eulerian multiphase model. According to above discussion, I have defined secondary phase straightaway in DEFINE>PHASES>SECONDARYPHASE as Carbon which is fluid (not a mixture). Primary phase which is defined as DEFINE>PHASES>PRIMARYPHASE as "Gas-mix" which is mixture with CO CO2 O2 N2 as species, am I right?? And second question, with above procedure, when i define heterogeneous reaction in DEFINE>PHASES>INTERACTION>REACTIONS and tried to define heterogeneous reaction between primary phase (air) and secondary phase. I can not see Carbon in species? Have i done any mistake while defining heterogeneous reaction? Thanks in advance. |
Catalytic reaction in multiphase flow (NEED HELP) | moataz.che | FLUENT | 0 | May 4, 2009 12:23 |
Surface Reaction Model or Heterogeneous Rxn Model? | satheeskannan | FLUENT | 0 | September 2, 2008 18:55 |
Ansys CFX10: multiphase reaction heat problem | CFDS | CFX | 1 | September 20, 2006 23:09 |
chemical reaction in multiphase flow | Domi | FLUENT | 2 | October 20, 2004 07:06 |
chemical reaction - decompostition | La S. Hyuck | CFX | 1 | May 23, 2001 00:07 |
