changing legend in FLUENT
Old   February 10, 2010, 11:13
Default changing legend in FLUENT
Akour
ak6g08 is on a distinguished road
hi all,
does anyone know if I can non-dimensionalize the legend in FLUENT with a constant number that I define...i.e. I would like the legend that indicates what each contour color is to be unitless. do i need to export in something like tecplot to do this? or can fluent handle it?
Thanks
akour
ak6g08 is offline   Reply With Quote
Old   February 10, 2010, 12:24
mjgraf is on a distinguished road
quickest would be just to use the calculator and create a new variable.
you using Ansys CFD to do the post processing?
mjgraf is offline   Reply With Quote
Old   February 10, 2010, 12:25
Akour
figured out a better way, so dont bother replying...
for anyone that is interested, or didnt know how to do this, like myself, go to define-->custom field functions, and then choose the field variable to non-dimensionalize from the drop down menu, put it in the calculator and divide by whatever you want, and then re-define that variable using some other name that you specify.
Then display contours of that new variable, which will be the original variable in non-dimensional form.
akour
Old   February 10, 2010, 12:26
Akour
thanks mjgraf!
i was actually posting my self-reply while you sent me yours! seems like the quickest way to do it if im not mistaken?
thanks
akour
Integration of a Custom C++ Model into FLUENT Syed Haider FLUENT 2 March 6, 2018 23:37
On Bug of Fluent 12.0 lzgwhy FLUENT 0 August 26, 2009 06:41
Running fluent in UNIX L3munoz FLUENT 10 August 26, 2009 04:59
Changing Display Legend from exp to float PHX FLUENT 1 May 30, 2009 18:34
Fluent: changing dimensions of a geometry genetaed Madhukar Rapaka FLUENT 3 October 12, 2005 11:40
