Fluent Axial Velocity Definition
Old   June 7, 2012, 09:34
Default Fluent Axial Velocity Definition
Zoe Burton
zoeburton1987 is on a distinguished road
In Fluent, when applying a pressure-inlet boundary with specification as a direction vector with a cylindrical coordinate system, is the axial component of velocity defined as perpendicular to the inlet plane?
I have an pressure inlet plane, inclined around 10degrees from vertical, and although I have not specified a radial velocity component when examining the velocity vectors of my converged solution I appear to have a radial component of velocity at inlet which disappears almost instantly downstream.
Thanks!
zoeburton1987 is offline   Reply With Quote
Velocity Fluctuations in Fluent Andrew FLUENT 14 August 24, 2015 00:26
fluent inlet velocity setup linyx FLUENT 5 February 23, 2012 11:36
few quesions on ANSYS ICEMCFD and FLUENT Prakash.Paudel ANSYS 0 August 12, 2010 12:07
User defined rotational velocity in FLUENT Abhinav FLUENT 1 June 10, 2003 08:31
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
