April 14, 2016, 23:51 |
How to read .hmf files
Anonymous
Rep Power: 12 |
Hi guys,
I have kept a transient run over the weekend on my pc and made it to save animation files for each time step. I left the default metafile format on and left. Later on Monday when I came back the system has restarted due to some problem and I don't have the final case and data files. But I have .hmf files of the run saved in the case folder for all iterations. How can I open them and see the results? |
April 15, 2016, 03:24 |
http://www.cfd-online.com/Forums/flu...hmf-files.html
Don't be too lazy to do some googling. And next time, set up the autosave for .cas/.dat files if you need the data later on.
If you're in need of some free quality CFD video tutorials - check out SiriusCFD @ YouTube |
April 15, 2016, 03:32 |
#3 | |
Anonymous
Rep Power: 12 |
Anyways, I just found out that we can just read the .cxa file that fluent creates along with .hmf files in any Fluent case and play it, create animation files. Thank you. |
How to read field files from the two different time directories | fumiya | OpenFOAM | 1 | August 1, 2021 06:58 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
Read CGNS files generated with Fluent v15 | Andrea1984 | Tecplot | 2 | October 16, 2014 10:50 |
read a list of files using fortran 77 | sp_song | Main CFD Forum | 1 | December 10, 2012 09:09 |
