porous pressure drop. Bugs?
Old   February 18, 2010, 03:32
Default porous pressure drop. Bugs?
wu
whiz is on a distinguished road
Hi, all,
I am trying to simulate a case in which I include the porous media.
I meet a problem: the mass flowrate from CFD is always larger than the measured data.
So I did a very simple case:
1. air with variable properties flow through a pipe.
2. All the domain is porous, and I defined the permeability and inetial coefficient.
Inlet: pressure and temperature
outlet: pressure
Then I compare the mass flowrate from FLUENT with that from Darcy-Forchheimer equation. The FLUENT software always over predict the mass flowrate.
Can anybody help me explain this? overcome this problem?......
Regards,
whiz is offline   Reply With Quote
Old   February 18, 2010, 17:28
Susan
hvem10 is on a distinguished road
And you have of course used Presto og higher order for pressure and minimum second order for momentum and calculated as double precision.
Pressure drop calculations (and mass flow as in your case) is always very sensitive to how accurate you model the problem.
Have you tried to change the mesh, pressure drop is also sensitive to the mesh. Mesh independant studies can easy show a difference in pressure drop on 10-20 %
hvem10 is offline   Reply With Quote
Old   February 19, 2010, 20:25
wu
Dear Susan,
Thanks for your reply.
But I still think there are problem with the porous model in FLUENT software.
You can try like this:
1. Define the permeability and inetial coefficient (as you want).
2. define the inlet as: velocity inlet, temperature
outlet: pressure
3. Compute the pressure drop in FLUENT when the case get converged
4. substitute the permeability, ineatial coefficient, viscosity, density and velocity into the "Darcy-Forchheimer" equation. You will find the pressure drop values are different.
PS: you can define the air properties as: ideal gas, use the sutherland model to compute the dynamic vistosity.
Regards,
Wu
Old   February 19, 2010, 20:27
wu
I am sure what I am talking about is independent on the mesh, convergence or something like that. It is because the porous model in FLUENT software has bug(s).
and, if you use CFX software, you can compare the two software. You will find the porous model in CFX is right.
Old   March 16, 2010, 13:02
Eric
cloudnqh is on a distinguished road
I'm also thinking something is wrong with porous medium model in Fluent. My case is different, if you compare the porous medium model results to detailed model results, the porous medium model always has lower pressure drop or lower mass flow rate if boundary conditions are the same for both models.
cloudnqh is offline   Reply With Quote
Old   March 16, 2010, 20:18
wu
Dear cloudnqh,
you are right!
I am sure there are bugs in FLUENT about the porous model.
Constant pressure drop condition Jonny6001 FLUENT 0 December 19, 2009 08:36
Pressure Drop in outlet Vent Abdul FLUENT 2 October 28, 2008 13:13
how to define pressure drop with CFX post alex CFX 0 September 20, 2007 18:31
pressure drop siddiqui FLUENT 2 March 15, 2006 07:13
Dissipation versus pressure drop Fabian Main CFD Forum 1 October 19, 2001 13:46
