steady or unsteady is better?
Hello to all!
To simulate stall in an airfoil with great accuracy what would give better results? A steady or unsteady solver? Thanks in advance. |
If you perform a steady simulation, you will not be able to find any periodic solutions. If this periodicity occurs in your situation, it may become difficult to get a convergent solution with certain discretization schemes. Transient simulations come with a price of course.
The problem i have with steady solution is that there is no stall, the Cl continues to rise! So, i was wandering if an unsteady solver could correctly calculate it.
Solve with unsteady first and then move to steady, it will give better convergence.
what time step should i use and how may iterations per time step?
del t = del x/v
del t= time step del x= smallest mesh size v= velocity or just put time step 0.001 and no. of time step (maximum) and 20 iteration per time step |
the smallest mesh size is the distance between the wall and the first cell adjacent to the wall or i understood wrong?
Smallest cell inside the domain.
Timestep = (1/10) * ((average cell size) / (average velocity)) |
