VOF model with planning vessel
Old   February 28, 2010, 13:03
Default VOF model with planing hull
Vincent Meertens
vmeertens is on a distinguished road
Send a message via MSN to vmeertens
For my master thesis i have to study the flow around a speedboat.
In gambit i've created a flow volume and substracted the hull from that volume. The BC's are: Pressure inlet, pressure outlet and moving walls, the hull is a fixed wal.
The water flows from left to the right with a constant speed (30m/s).
In Fluent i've followed the next steps:
Steady Pressure based (Gravity enabled).
VOF with Realizable k-epsilon.
Material, phases, BC are defined the way it should be. (with specified density set to 0).
Solution methods: Scheme: Simple, Pressure: Presto, Momentum: Power Law, Volume Fraction: Modified HRIC, rest: Power Law.
Under-relaxation factors are decreased.
Initialization on Inlet.
start calculation.
When i check the results i get the following solution.
In a symmetry plane i want to see the contours of the 2 phases. When i plot them i get the following (with 2 phases):
There's no contact between the hull and the water. But the solution seems converged (Cl is constant and de residuals are converged till 10E-3)
The wave after the hull looks correct but the forces (lift and drag) are to big.
When i define 4 phases i get the following result:
This seems a lot better but i cant give a physical explanation to 4 phases.
So my question is: are my calculations wrong or is this 'visual' result just a part of postprocessing and i shouldn't pay to much attention to the colors?
Thanks in advance!
Vincent
vmeertens is offline   Reply With Quote
Old   March 1, 2010, 07:29
Vincent Meertens
I did a transient calculation after this, but it doesn't change anything to the results.
The initial water surface is set to y=0, so it should touch the hull in the middle. The hull is set under an angle of 2° (compared with pictures of the real boat)
Old   March 17, 2010, 01:51
-mAx-'s Avatar
Maxime Perelli
how did you initialize the vof (water)
Once the initialization is done, check the distribution of vof.
Does your free surface agree with what you want?
Old   March 25, 2010, 15:49
Vincent Meertens
Hey,
The vof is patched as following:
Adapt -> Region: dimensions of the volume of water.
Initialize from inlet
Patch -> Phase: water -> Volume fraction: 1 -> Hexadronr0
Patch -> X-Velocity -> Value: 30m/s -> Fluid
At t = 0 the free water surface is as it should be.
Now i'm doing the simulation with a better mesh thanks to mAx
Old   August 9, 2013, 16:12
Default air phase being formed on the bottom of the hull
Deepak Bansal
Deepak Bansal is on a distinguished road
hey buddy i am also facing same problem in planing craft that air phase being formed on the bottom of the hull.................how did u solve this problem.................reply as soon as possible...............
Deepak Bansal is offline   Reply With Quote
can melting model and vof model be used together? wanghong FLUENT 3 February 26, 2017 23:49
A Problem with setting the time step in VOF model Le FLUENT 2 July 20, 2006 22:00
free surface of VOF and melting model? wanghong FLUENT 3 March 13, 2006 09:57
help needed for vof model yan FLUENT 3 December 16, 2005 01:17
VOF Model Arman Altincatal FLUENT 4 April 12, 2002 16:26
