Need help : natural convection in inclined convergent channel
Old   October 21, 2012, 12:08
Default Need help : natural convection in inclined convergent channel
Glare is on a distinguished road
hello all, first of all, sorry for my bad english
im still newbie here and hope to get some help
i have some problem on inclined convergent channel system.
The system has 2 inclined wall with same temperatur (i set 332K for both wall). The bottom & top temperatur is set to 300K. The bottom side is inlet and the top side is outlet. What boundary condition should i choose for top & bottom? is that true if i set the top & bottom side of system is set to pressure outlet & pressure inlet?
In material panel, i set density properties to boussinesq, should i change its value (default value = 0)?
When i have convergence problem, i try to change the under relaxation factor, i decrease it gradually until the residual almost constant. Is there any limit value in decreasing uder relaxation factor?
Any help would be very useful to me, thanks
Glare is offline   Reply With Quote
Old   October 21, 2012, 12:31
SSL
msaeedsadeghi is on a distinguished road
1- Don't change fluent default values without information
2- You should define that density value. Set the density. Zero is incorrect.
3- If you have a natural convection in a closed box, all boundary conditions should be as wall.
4- Natural convection is highly sensitive to mesh size. change it to get a good result.
msaeedsadeghi is offline   Reply With Quote
natural convection problem with radiation jorien CFX 0 October 14, 2011 09:26
modeling natural convection in tilted channel Luis FLUENT 0 April 27, 2008 15:56
Coupled vs Seg - Natural vs. Forced Convection Alex Siemens 5 December 12, 2007 04:58
Approximate Mixing due to Natural Convection Greg Perkins Main CFD Forum 0 February 12, 2003 18:43
natural convection in a sealed enclosure James Main CFD Forum 4 April 2, 2001 15:48
