Gauge pressure: NEGATIVE?
Old   March 3, 2010, 16:07
Default Gauge pressure: NEGATIVE?
sarav is on a distinguished road
I'm using a pressure outlet with target mass flow rate.
The reference pressure in the aerodynamic field is 0 Pa (I've changed nothing of the default settings).
So, if I want air to go out from the domain by the pressure outlet, I must use a negative gauge pressure, it's right?
Thank you!
sara
sarav is offline   Reply With Quote
Negative pressure! Neel CFX 0 March 19, 2008 07:47
negative static pressure at inlet nino FLUENT 7 July 27, 2007 08:22
gauge pressure sheila FLUENT 15 July 9, 2007 22:30
Negative Pressure S Christopher CFX 2 October 6, 2005 18:14
negative pressure Mark Render Main CFD Forum 8 April 23, 2002 06:02
