March 11, 2010, 17:20 |
Calculating torque
I have a rotor/stator/housing model that rotates around the vertical (Y) axis. I would like to measure the torque acting on the rotor blades. Is there a way by which this can be done in Fluent?
I have layered each of the rotor blades in ICEM. So, ideally, I should be able to get the torque acting on each of these blades, from FLUENT. Please help.. Thanks. |
March 11, 2010, 21:10 |
Jonny
Surely the torque can be calculated from the integral of the pressure on the blades times the effective radius.
March 12, 2010, 02:22 |
Maxime Perelli
Rep Power: 41 |
report/forces...
choose moment (or torque I don't remember anymore), and set the right point for computing it. Check that the torque around Y-axis doesn't change when you set it with another point (but still on the Y-axis)
In memory of my friend Hervé: CFD engineer & freerider |
calculating torque | shawn123 | STAR-CCM+ | 3 | January 23, 2010 22:32 |
Calculating torque | Andrew | FLUENT | 5 | September 4, 2007 12:10 |
turbine torque calculating in Fluent | Bagus Putra Muljadi | FLUENT | 0 | May 18, 2006 03:34 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 18:27 |
about use macro to compute torque in TASCflow | lancy | CFX | 0 | June 10, 2003 07:19 |
