March 29, 2010, 09:10 |
VOF - Patching
SK
Halo,
I am working with VOF in 3D. In VOF patching is required for secondary phase. In case of simple geometries its works fine with the dimension. When we have some triangular geometry, How can we patch the secondary phase? Sketch of the geometry looks like this.. regards SK |
March 29, 2010, 09:12 |
Sebastian Gatzka
Rep Power: 20 |
Sorry to ask, but what is 'patching'?
Schrödingers wife: "What did you do to the cat? It's half dead!" |
March 29, 2010, 09:16 |
SK
In VOF model, while initialising we need to fill the secondary phase in the specific region and the rest with primary phase. This can be done by marking some region using adapt panel. and then using solve->initialise--> patch.
March 29, 2010, 16:20 |
Sebastian Gatzka
Rep Power: 20 |
Sorry, I'm out. I have made experience with VOF and its theoretical background using OpenFOAM. Your question is too FLUENT-related.
I'm afraid I can't help you there.
March 31, 2010, 10:42 |
Martin
doesn't Fluent mark the cells necessary if u just put in the coordinates? I suppose so ...
March 31, 2010, 12:57 |
Svetlin Filipov
Define the region as a separate volume and patch it
April 2, 2010, 01:56 |
VOF - Patching
sunqiang
You can first set a region in Adapt->region in fluent ,you can either set a quad region or circular one using the input coordinate . Then then you can patchthe after initialization , in the patch panel choose the second phase and set the value to 1 or so. you can check it using display->contour ->phase fraction
Hope it helps matt |
UDF Defining VOF Free Surface at Outlet | Alex | Fluent UDF and Scheme Programming | 13 | August 8, 2012 16:50 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
VOF UDF FOR PATCHING SINUSOIDAL FREE SURFACE | beginner | FLUENT | 1 | September 10, 2007 02:16 |
VOF Patching fluids at an angle? | Brian | FLUENT | 0 | October 26, 2005 20:58 |
Difficult BCs about Freesurface Simulation by VOF | Yongguang Cheng | FLUENT | 0 | September 19, 2003 07:39 |
