April 2, 2010, 05:56 |
Setting up for Rotating 2D straight channel
Pawan K Garg
Rep Power: 16 |
Hello ! I am Pawan Garg.
I have been trying to setup FLUENT boundary conditions for the problem of Turbulent flow through a straight channel which is rotating at certain RPM in the plane of the channel. I have not been able to get a converged solution! What is the best way to set-up such a flow in the rotating reference frame. I shall be thankful to you if you can guide me over the detailed setup of fluent boundary condition that can be suitably used for simulating rotating straight 2D channel. Thank you in advance. |
boundary condtions, rotating channel |
Open Channel Flow - Setting Boundary Conditions | Christine Sindelar | FLUENT | 6 | June 6, 2011 04:11 |
Actuator disk model | audrich | FLUENT | 0 | September 21, 2009 07:06 |
Where's the singularity/mesh flaw? | audrich | FLUENT | 3 | August 4, 2009 01:07 |
Open Channel Boundary Conditions via journal | Matteo | FLUENT | 0 | January 21, 2008 11:05 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
