Is it possible to export a mesh from FLUENT in v18/19? |
June 25, 2019, 16:09 |
Lee Strobel
Rep Power: 9 |
I have seen some other questions about this; however, they seem a bit out-of-date. Is it possible to export a mesh file from FLUENT in either version 18 or 19? (From the main FLUENT program, not FLUENT meshing)
For example, I have a tet mesh that I made in ANSYS and then converted to polyhedral in FLUENT. I would like to export the polyhedral mesh file and import it into OpenFOAM. |
June 28, 2019, 10:27 |
Lucky
Rep Power: 65 |
There are two openfoam utilities for this: fluentMeshToFoam and fluent3DMeshToFoam.
Have you looked into these? I don't get what's so special about Fluent 18/19. |
June 28, 2019, 11:08 |
Lee Strobel
Rep Power: 9 |
@LuckyTran: I am trying to use fluentMeshToFoam to convert from FLUENT mesh format to OF. However, unless I am mistaken, I understand those tools work on a .msh file, not the FLUENT .cas file.
So, my question is whether it is possible to export a .msh file from FLUENT, for those specific versions? |
July 2, 2019, 13:02 |
I couldn't find the direct method/command to export a .msh file from Fluent (v19.1). Instead I'm doing the followings to get the .msh file from .cas file: 1. In Fluent Solution Mode (normal mode), write a .cas file 2. Launch Fluent in the Meshing Mode by ticking "Meshing Mode" in the Fluent Launcher 3. Read the .cas file just saved by File>Read>Mesh... then it prompt "Reading a case file as a mesh file results in loss of boundary conditions." Press OK. 4. Write the mesh as .msh by File>Write>Mesh... There may be a better way but this worked for me, though I haven't tried with polyhedral mesh. |
July 2, 2019, 13:43 |
Lucky
Rep Power: 65 |
You can use fluentMeshtoFoam on a case file
A fluent .msh file is just a stripped down .cas file |
July 2, 2019, 16:28 |
Lee Strobel
Rep Power: 9 |
Ok, thanks to you both for the info. This is very helpful.
Can Fluent meshing export mesh into CGNS? | Renold | FLUENT | 1 | April 25, 2022 06:27 |
[Other] ANSYS to Fluent mesh export in ASCII format | johannes | ANSYS Meshing & Geometry | 64 | October 19, 2021 20:13 |
[ICEM] Problems with export 2D mesh from ICEM to FLUENT | newcomer | ANSYS Meshing & Geometry | 54 | September 20, 2014 12:40 |
export mesh from fluent | hamednoordoost@yahoo.com | FLUENT | 3 | May 11, 2013 09:51 |
Export mesh from Fluent in Nastran format | Wieland | FLUENT | 9 | October 19, 2012 09:16 |
