particle flow in Fluent
Old   April 15, 2010, 06:16
Default particle flow in Fluent
Sarah
spring is on a distinguished road
I want to simulate a particle flow in Fluent and I know that I have to use the discrete phase model, but I didn't figure out where I can detremine the particle size (diameter or radius) and the mass of a single particle or of all particles together. Furthermore I would like to determine the inlet flow profile (e.g. a parabolic profile) for the particles if possible. Can anybody please tell me how I can do this?
spring is offline   Reply With Quote
Old   April 19, 2010, 04:40
Sarah
Hey,
doesn't really anybody of you have experience with the simulation of particle flow in FLUENT. I would really be thankful if you could at least tell me anything about the particle flow simulation or how I can apply it.
Thanks...
Old   April 19, 2010, 06:13
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
Concerning particle diameter and mass you can specify eveything from within the injection window.
Your particles will follow the flow, so maybe you will have a parabolic inflow if you have one for your velocity field?
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   April 19, 2010, 07:10
Wink
anonym
Laci is on a distinguished road
Actually, I don't think this model would be very accurate...
Anyway, Models/Discrete Pahes Model/Interaction with Continuous Phase (click)
Then 'Injections...' next to the OK button.
'Create'. On this panel you can choose if you need single point injection or surface etc. You have to define the point/line/surface you want to inject the particles; the material, mass, diameter, flow rate, temperature and the initial velocity.
If you want more injections with different materials, you have to add the new material in the 'Materials' panel.
Laci is offline   Reply With Quote
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 01:29
About Particle velocity of DPM in Fluent? long zhengwei FLUENT 0 March 13, 2009 04:02
Unsteady Flow in FLUENT Vidya Raja FLUENT 0 November 1, 2005 17:54
Can FLUENT solve particle flow? Junmeng Cai FLUENT 0 August 30, 2004 08:54
Flow visualization vs. Calculated flow patterns Francisco Saldarriaga Main CFD Forum 1 August 2, 1999 23:18
