April 17, 2010, 06:03 |
Flapping Wing motion
Balkrishna Patankar
I am doing a CFD analysis of flapping wing motion in FLUENT . For the same I have written a UDF which looks like :
#include "udf.h" DEFINE_CG_MOTION(myudf, dt, v_cg, omega, time, dtime) { Thread *t; real c=0.2; real omega_t=6.28; NV_S(v_cg, =, 0.0); NV_S(omega, =, 0.0); t=DT_THREAD((Dynamic_Thread *)dt); v_cg[1]=2*3.14*c*cos(omega_t*time); omega[2]=3.14*3.14*sin(omega_t*time)/4; Message("time:%f vx_cg:%f vy_cg:%f omegaz:%f \n",time, v_cg[0],v_cg[1],omega[2]); } Also another option is actually defining the path taken by the CG in time ..... writing a profile file .... . How does one actually write a profile file ??? |
August 3, 2010, 02:13 |
rotation about z axis
ahmad
hi dear balkrishna...
long ago you were studying a case that contained flapping wing motion, now i'm working on something like that,i sent you two images that both of them are kind of peristaltic pump,i want to rotate two/one small cylinder about z axis,i should write an udf,i've written an udf for this but does not work;I will be thankful if you could help me out looking forward to ur help. |
August 3, 2010, 02:14 |
ahmad
sorry I forgot to attach images;
August 3, 2010, 02:17 |
Balkrishna Patankar
Yes write a UDF ... it will be simpler ... please attach the UDF ... or paste the code ....
August 3, 2010, 02:29 |
ahmad
dear balkrishna,it's kind of you to reply my post
i use the following udf # include "udf.h" # include "dynamesh_tools.h" DEFINE_CG_MOTION(pump,dt,vel,omega,time,dtime) { Thread *t; real freq_t; NV_S(vel,=,0.0); NV_S(omega,=,0.0); if(!Data_Valid_P()) return; freq_t = 4.0; t= DT_THREAD((Dynamic_Thread*)dt); vel[0] = 0.0; vel[1] = 0.0; vel [2] = 0.0; omega [0] = 0.0; omega [1] = 0.0; omega [2] = freq_t; } in your opinion is that what i want,if yes what's the problem that it does not work,if not plz help me write an appropriate udf... |
August 3, 2010, 02:31 |
Balkrishna Patankar
what doesnt work in this ... the udf is fine .... what are the errors you are getting ?
are you getting negative volumes in the mesh ? Also use cg_vel and cg_omega for the variables vel and omega ..... |
August 3, 2010, 02:34 |
ahmad
no i mean the small circle does not rotate about center of bigger circle,i have problem in motion!
August 3, 2010, 02:35 |
Balkrishna Patankar
yes ... i faced a similar problem .... use cg_vel instead of vel and cg_omega instead of omega
August 3, 2010, 02:39 |
ahmad
plz explain it more, how should i do it in udf,how can cg_vel rotate small circle about z axis???
August 3, 2010, 02:41 |
Balkrishna Patankar
try this udf ....
# include "udf.h" # include "dynamesh_tools.h" DEFINE_CG_MOTION(pump,dt,cg_vel,cg_omega,time,dtime) { Thread *t; real freq_t; NV_S(vel,=,0.0); NV_S(omega,=,0.0); if(!Data_Valid_P()) return; freq_t = 4.0; t= DT_THREAD((Dynamic_Thread*)dt); cg_vel[0] = 0.0; cg_vel[1] = 0.0; cg_vel [2] = 0.0; cg_omega [0] = 0.0; cg_omega [1] = 0.0; cg_omega [2] = freq_t; } |
August 3, 2010, 02:54 |
#11 |
Balkrishna Patankar
yes it can ....
August 3, 2010, 03:50 |
#12 |
ahmad
dear balkrishna...
i compiled ur udf and three images that i sent u are results,as u can see small cylinder changes its position so small, i want to move center of the cylinder on the inner edge of bigger cylinder,how can i do this large displacement?? Attachment 4299 Attachment 4300 http://www.4shared.com/file/R2SbkdqT...ltic-pump.html |
August 3, 2010, 03:55 |
#13 |
Balkrishna Patankar
i have dans guardian banning the attachment download .... read the documentation for larger displacement .... ....
August 3, 2010, 06:08 |
#14 |
ahmad
i did not understand ur post,i had another post in mind
August 3, 2010, 06:10 |
#15 |
Balkrishna Patankar
check the fluent docs ....
November 1, 2012, 09:20 |
#16 |
Vidit Sharma
hi,
I am trying to move a 2d cylinder in y direction by using UDF:- # include "udf.h" # include "dynamesh_tools.h" DEFINE_CG_MOTION(pump,dt,cg_vel,cg_omega,time,dtim e) { Thread *t; real freq_t; NV_S(cg_vel,=,0.0); if(!Data_Valid_P()) return; freq_t = 0.01; t= DT_THREAD((Dynamic_Thread*)dt); cg_vel[0] = 0.0; cg_vel[1] = freq_t; } But I am having a problem while compiling it in Visual Studio Command Prompt. While executing nmake command to compile an error is appearing which is saying NMAKE : fatal error U1077: "sed" :return code '0X1' can anybody tell how to eliminate this error???? Thank You Regards Vidit Sharma |
November 1, 2012, 09:34 |
#17 |
Balkrishna Patankar
try interpreting it .... do not compile it.
November 1, 2012, 09:41 |
#18 |
Vidit Sharma
April 13, 2016, 04:16 |
flapping wings
#19 |
mohamed
Rep Power: 10 |
I am doing a CFD analysis of flapping wing motion in FLUENT and I need udf code to define the motion I do not know how to write it can any one help me with it thanks
April 13, 2016, 15:42 |
CFD udf code fluent
#20 |
mohamed
Rep Power: 10 |
[QUOTE=moh_zain;594803]I am doing a CFD analysis of flapping wing motion in FLUENT and I need udf code to define the motion I do not know how to write it can any one help me with it thanks
flapping, fluent, profile, udf, wing |
Modelling flow around a flapping wing | balkrishna | Main CFD Forum | 1 | February 18, 2010 23:32 |
ask help about flapping wing UDF | aeropeng | Fluent UDF and Scheme Programming | 0 | December 24, 2009 22:09 |
Flapping wing by moving frame | loogtaan | FLUENT | 1 | October 11, 2007 02:48 |
Help on the flapping wing | Kearney | Main CFD Forum | 1 | May 28, 2003 09:50 |
