How to set mass flow rate and pressure in one inlet? |
March 31, 2018, 05:54 |
Nicodemus Sigit Sutanto
Currently, I'm running simulation of heat exchanger which has two different inlet and outlet. One for hot fluid and another is cold fluid. Each inlet has its own mass flow rate and pressure. I use mass flow inlet BC to input the mass flow rate, but I don't know where to input the pressure since the Fluent help said that the value of supersonic/initial gauge pressure is neglected if the condition is in subsonic. My question is what BC I have to use for this condition, especially for the inlet and the outlet.
Thank you |
mass flow inlet and pressure outlet with target mass flow rate | Zigainer | FLUENT | 13 | October 26, 2018 05:58 |
Pressure Outlet Targeted Mass Flow Rate | LuckyTran | FLUENT | 1 | November 23, 2016 10:40 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Mass flow rate prediction of Purge control valve using set pressure drop | enr_venkat | CFX | 11 | February 27, 2014 11:30 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
