April 15, 2009, 15:44 |
Wind turbine simulation help
kirit
Rep Power: 17 |
I am trying to simulate 2D savonius rotor wind turbine. but i have done every thing good so far expect the post processing one. I am trying to calculate the Drag coefficient and Lift coefficient of my work. The way which i am using right now. Report > Forces> then i am going to x and y direction forces. Then converting the the forces in to tangential force and normal force using those two Equation : Fn= Fx*SinA+Fy*CosA Ft=-(Fx*CosA-Fy*SinA) Here is A is 0 for balde1, 120 for blade2, 240 for blade 3 . After that i am using the formula Cd=Fd/(1/2*p*U*U*A) Cl=Fl/(1/2*p*U*U*A) to calculate drag and lift. But i am not getting the value which i am suppose to get for this work. Am i going to the right way ?? I have attached jou file i am not sure you will be able to see that please let me know. i cant upload the cas file as the size is more than 97 kB. thanks in advance Kirit |
April 16, 2009, 10:53 |
kirit
Rep Power: 17 |
May 18, 2009, 11:10 |
Thanh Nha Nguyen
Rep Power: 16 |
Hi kirit!
I doing the same problem to u. But i don't know how to Apply the inlet and outlet. How can we apply the angular velocity of rotor what the unknown of turbine problem? |
June 23, 2009, 06:49 |
wind turbine rotor
hi all,
i am also doing same problam please send me your case file and gambit file,i will check it,
sivaramakrihnaiah |
June 23, 2009, 10:09 |
kirit
Rep Power: 17 |
I cant upload file coz its big than they permit. if you give me your mail address i can send it to you
thanks Kirit |
June 24, 2009, 06:47 |
windturbine simulation help
Hi,how are you,
Thankyou very much, My mail ID:siva@green-line.com,malayathisiva@gmail.com, sivaramakrishnaiah@live.com
sivaramakrihnaiah |
April 22, 2010, 22:45 |
wind turbine
#7 | |
yashwant
Rep Power: 16 |
thanks -- |
April 22, 2010, 22:48 |
#8 | |
yashwant
Rep Power: 16 |
thanks -- |
April 23, 2010, 00:15 |
wind turbine design
#9 |
Hi
This is my DESIGN Calculations,but i was done in CFX,i know in little bit in fluent and gambit http://www.4shared.com/document/Vnjp...dturbine3.html http://www.4shared.com/document/KaBz..._TURBINE1.html
sivaramakrihnaiah |
April 23, 2010, 00:25 |
#10 |
yashwant
Rep Power: 16 |
sir i hav calculated all this by developing the code for BEMT meathod. but i require the guidence regarding CFD analysis either in fluent or cfx. how to calculate all thins with these softwares
April 23, 2010, 04:24 |
wind turbine
#11 |
Hi
ok, very long back i was done simulation in CFX-11 Boundary conditions: Inlet:Stagination Temperature and Velocity(sunsonic) Outlet: static pressure(subsonic) K&e model,boundary layer 2mm
sivaramakrihnaiah |
Display Modes | |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
Wind Turbine Dynamic Simulation | Michele | FLUENT | 2 | June 10, 2009 07:14 |
Wind turbine simulation | Saturn | FLUENT | 1 | June 16, 2006 02:12 |
Wind turbine simulation | Saturn | Main CFD Forum | 1 | June 12, 2006 03:57 |
CFX-TASCflow, wind turbine simulation | Sac | CFX | 0 | June 7, 2004 03:33 |
