May 4, 2010, 21:18 |
heat generation inside fluid
hi,
Fluent is new for me so i'm new in forum. I need your help about heat generation in flow. i have a pipe and inside the pipe there is a heat generating fluid. i learned from user guide that it is possible to add heat generation from the walls but in my case heat generation occurs in the fluid. so i cannot find how to add it. is it possible to add constant heat generation inside the flowing fluid? if so how? waiting for your respond. thanks Omar |
May 5, 2010, 10:29 |
Rep Power: 16 |
hi
the heat generation is possible apply to the fluid. the condiction is on the region of fluid so you able the source term in the windows of water region. |
May 5, 2010, 11:30 |
#3 | |
Ling
Rep Power: 16 |
is the heat generation zone a moving zone, like moving with the fluid. or just stationary sitting there generating heat.
If the second one, you just need to create a separate zone for it and set the 'source term' in this zone. Quote:
May 5, 2010, 12:27 |
Thank you very much bob12, i found the adding section on program. it is really easy but i couldn't find it first.
nstar i should thank you too. it is a moving fluid. and if heat generation is constant, we can add it from the program easily. but if it's not constant, i will ask you again. Omar |
Display Modes | |
Simulation of a single bubble with a VOF-method | Suzzn | CFX | 21 | January 29, 2018 01:58 |
Solid / Fluid Heat Transfer | Koranten | FLUENT | 3 | March 19, 2011 08:21 |
Concentric tube heat exchanger (Air-Water) | Young | CFX | 5 | October 7, 2008 00:17 |
heat generation | jamal | FLUENT | 0 | April 10, 2008 00:50 |
Heating of a solid cylinder with internal heat generation | Sriram Popuri | Main CFD Forum | 6 | July 13, 1999 19:09 |
