UDF for a field size
I want to see the influence of a magnetic field on iron particles in a tube. For this reason I have to couple the (magnetic fiel -) matrix (x,y,z-coordinates, F_mag) by a UDF. Furthermore I want the UDF to execute or to be triggered at the end of the flow process, i.e. at the end of the solution calculation. Does anybody know how 1. I can couple a matrix which should be placed over the hole mesh by a UDF and 2. I can bring this UDF to execute at the end of the calculation of the particle trajectories or after the particle trajectories are calculated Concerning my second question I think I can use the "DEFINE_EXECUTE_AT_END" UDF, but I am not shure. So I would be really thankful for some help or ideas from you. spring |
