help,why the negative energy source does'nt make the temperature decrease, thank you! |
November 6, 2009, 03:04 |
patrick
Rep Power: 17 |
I am simulating the over-heated liquid evaporation. but the temperature did not decrease. Actually it should because some liquid evaporate into gas and the latent heat is from the liquid. I have done this for over months, but little progress is obtained. who can help me? I would appreciate your help. the model is as below:
liquid saturation temperature:3.7K liquid initial-state temperature:4.2K the liquid is in the state of over-heated. It should be evaporate by absorbing the energy of partion of liquid. the model is vof. udf is as below: DEFINE_ADJUST(m_dot_adjust, domain) {cell_t cell; Thread *mix_th,*pri_th ,*sec_th; Domain *d; d=Get_Domain(1); thread_loop_c(mix_th,d) {pri_th= THREAD_SUB_THREAD(mix_th, 0); sec_th= THREAD_SUB_THREAD(mix_th, 1); begin_c_loop(cell,mix_th) { if(C_T(cell, mix_th)>=T_SAT) { m_dot_l=0.1*C_VOF(cell,pri_th)*C_R(cell,pri_th)*(( C_T(cell,mix_th)/T_SAT)-1); C_UDMI(cell,pri_th,3)=m_dot_l; m_dot_l_m=0.1*C_R(cell,pri_th)*fabs(C_T(cell,mix_t h)-T_SAT)/T_SAT; C_UDMI(cell,pri_th,4)=m_dot_l_m; m_dot_l_eng=0.1*C_VOF(cell,pri_th)*C_R(cell,mix_th )/T_SAT; C_UDMI(cell,pri_th,5)=m_dot_l_eng; } else { m_dot_v=0.1*C_VOF(cell,sec_th)*C_R(cell,sec_th)*(( C_T(cell,mix_th)/T_SAT)-1); C_UDMI(cell,sec_th,9)=m_dot_v; m_dot_v_m=0.1*C_R(cell,sec_th)*(-(C_T(cell,mix_th)/T_SAT)+1); C_UDMI(cell,sec_th,10)=m_dot_v_m; m_dot_v_eng=-0.1*C_VOF(cell,sec_th)*C_R(cell,sec_th)/T_SAT; C_UDMI(cell,sec_th,11)=m_dot_v_eng; } }end_c_loop(cell,pri_th) } } DEFINE_SOURCE(liq_src, cell, pri_th, dS, eqn) { Thread *mix_th,*sec_th; mix_th = THREAD_SUPER_THREAD(pri_th); sec_th = THREAD_SUB_THREAD(mix_th, 1); if(C_T(cell, mix_th)>=T_SAT) {source0=-C_UDMI(cell,pri_th,3); dS[eqn]= -C_UDMI(cell,pri_th,4);} else {source0=C_UDMI(cell,sec_th,9); dS[eqn]=0;} C_UDMI(cell,pri_th,12)=source0; return (source0); } DEFINE_SOURCE(gas_src, cell, sec_th, dS, eqn) { Thread *mix_th,*pri_th; mix_th = THREAD_SUPER_THREAD(sec_th); pri_th = THREAD_SUB_THREAD(mix_th, 0); if(C_T(cell, mix_th)>=T_SAT) {source1=C_UDMI(cell,pri_th,3); dS[eqn]= 0;} else {source1=-C_UDMI(cell,sec_th,9); dS[eqn]=-C_UDMI(cell,sec_th,10);} C_UDMI(cell,sec_th,13)=source1; return (source1); } DEFINE_SOURCE(mixture_eng_src, cell, mix_th, dS, eqn) { Thread * sec_th,*pri_th; pri_th= THREAD_SUB_THREAD(mix_th, 0); sec_th= THREAD_SUB_THREAD(mix_th, 1); if(C_T(cell, mix_th)>=T_SAT) {source3=-20800*C_UDMI(cell,pri_th,3); dS[eqn]= -20800*C_UDMI(cell,pri_th,5);} else {source3=20800*C_UDMI(cell,sec_th,9); dS[eqn]=20800*C_UDMI(cell,sec_th,11);} C_UDMI(cell,mix_th,14)=source3; return (source3);} the evaprated liquid is monitored. the source0 is negative and the source1 is positive. the source3 is negative. therefore, the source3 is added into the energy equation, the temperature should decrease, why it increase? who can help me, it drives me crazy. |
November 6, 2009, 03:07 |
patrick
Rep Power: 17 |
my email address is bj-luo@hotmail.com, welcome everyone to communicate with me, thank you very much!
November 6, 2009, 04:04 |
Shane
Rep Power: 16 |
Try to check the value of C_UDMI(cell,sec_th,(3,4,5,9,11) and source1(2,3).
Try to check these two steps. 1) Are they are geeting properly assigned. 2)Also I believe real value are getting truncated. sircorp |
November 6, 2009, 10:08 |
patrick
Rep Power: 17 |
hello sircorp,
thank you for your help. the C_UDMI(cell,sec_th,(3,4,5,9,11) and source1(2,3) are correct. source0=-1.79,sour1=1.79,source3=-1.79*20800; I have spent lots of time on it. it is very strange. the energy source is negative, but the temperature is increasing. begging for help!!! |
November 8, 2009, 07:25 |
patrick
Rep Power: 17 |
maybe the problem is from the enthalpy. I assigned both the gas' and the liquid's standard state enthalpy is 0 with a 4.2K reference. but now I found the enthalpy is -1058514j/kg for liquid and -2147306j/kg for gas at 4.2K. I feel confused "is not it 0"? why? who can give me some words, thank you
November 8, 2009, 10:54 |
patrick
Rep Power: 17 |
is there someone who give me some words about re-defined the enthalpy? h=cp*t? is it possible?
May 12, 2010, 17:39 |
Wei Shao
Rep Power: 17 |
Have you solved your problem? I have the same problem
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 15:45 |
How to set Temperature as heat source in Solids | shahpar73 | CFX | 2 | August 20, 2009 18:51 |
flow in pipe with momentum and energy source | Atit Koonsrisuk | CFX | 3 | March 29, 2005 16:58 |
How to define energy source? | Marie | FLUENT | 2 | September 19, 2002 05:27 |
Why FVM for high-Re flows? | Zhong Lei | Main CFD Forum | 23 | May 14, 1999 13:22 |
