May 20, 2010, 12:02 |
operating temp. mterials prop.??
engahmed
Rep Power: 16 |
Hi CFD users,
I am working on heat transfer from a pipe embedded in a porous medium superimposed with a fluid layer. I am confused with what operating temperature to put. I am using the boussinesq approximation, and was wondering if I put the operating temperature as the temperature which I defined the fluid properties at? or is the operating temperature, the lowest temperature in the system? Any reply will help! |
operating pressure and operating density | phil | FLUENT | 5 | November 7, 2017 17:02 |
CFB+wall BC for solid vel and gran temp | Umesh | FLUENT | 2 | September 10, 2013 17:21 |
REAL GAS UDF | brian | FLUENT | 6 | September 11, 2006 08:23 |
Is "operating density" sensitive to the resluts? | Joe | FLUENT | 0 | August 29, 2006 11:02 |
Operating Pressure | Nori | FLUENT | 1 | April 7, 2004 11:29 |
