Cp values for F3 rear wing for a 4th year thesis
Old   October 15, 2004, 02:51
Default Cp values for F3 rear wing for a 4th year thesis
Joe Bryant
Hey,
i am interested to know by setting an area of the aerofoils of a rear wing value in reference areas does that at all interact with calculating the pressure coefficient of say of an 3d aerofoil section.
I noticed that i haven't touch the reference values and i know that when i calculate lift an drag which i will do from the pressure coefficents i have to add the area into it however do i need to do anything to the pressure coeffient (i.e.) incorporate area.
as cp= p -p_inf / (0.5 x density x velocity^2)
also i am only modelling half the rear wing so does that mean that when i calculate lift and drag i only use the area of half the wing (i.e. the two aerofoil elements) and is the area just the reference area of the aerofoil shapes i.e. span x chord. or is it the frontal area, any help would be greatly appreciated. very much so.
cheers joe bryant
Old   October 15, 2004, 03:36
Default Re: Cp values for F3 rear wing for a 4th year thes
Luca Cavagna
Hi Joe! the surface area you should use is the HALF planform surface of the full-wing since you're using half of the real model. The cp value doesn't depend on the reference area. Only the drag and the lift coefficient depend since they come from the sum of the product betwen the element area and its cp (projected then along the direction you specificed; for ex.(1,0,0)). CL=net AERO_FORCE/(0.5 density vel^2 S) I hope to be clear. Luca
Old   October 15, 2004, 03:42
Joe
Thank you so much for your help its much appreciated.
Cheers Joe Ps. will put you as an acknowledgement in my 4th year thesis for aeronautical engineering Sydney University
cheers once again
Old   October 15, 2004, 06:37
Luca Cavagna
You're welcome...if you had any problem with Fluent just write!I'd be glad to give you some suggestions (if I can...). Luca
Old   June 10, 2010, 23:40
Shreyas
shreyas is on a distinguished road
Originally Posted by Luca Cavagna
;115554
Hey luca...how do I get the values of cp in the right range...I get it in the range of 1e6 etc...I need to compare it with theoretical results
shreyas is offline   Reply With Quote
Question about reference values --> Area (multi element wing) Zweeper FLUENT 7 March 28, 2010 11:29
[Other] Question about aerodynamik design (rear wing) Zweeper ANSYS Meshing & Geometry 1 March 23, 2010 08:35
Study of a Rear wing Crazer FLUENT 2 August 10, 2009 03:45
Wing Drag Values Ed Reed FLUENT 1 November 16, 2004 16:30
help needed about phase change Yanhu Guo Main CFD Forum 4 January 23, 2001 23:16
