reverse flow
Old   June 2, 2010, 03:24
Default reverse flow
ali
alikami is on a distinguished road
simulating over expanded flow in nozzle at ambient condition gives reverse flow at exit ,but actually it will happen.
am i correct???
alikami is offline   Reply With Quote
Old   June 2, 2010, 04:19
mannobot is on a distinguished road
It will happen. You will get flow separation at the wall. Your boundary layer gets thicker and the air from the environment enters the domain. But just close to the wall. At the center of your jet there won't be any reverse flow. You will get shock waves which do adapt the pressure.
mannobot is offline   Reply With Quote
reverse flow error message Kiraka FLUENT 12 June 3, 2021 20:56
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 05:44
Reverse flow in the VOF model yan FLUENT 1 May 26, 2005 09:14
reverse flow Giovanni FLUENT 11 October 15, 2001 03:01
reverse flow in pressure-outlet? hanjun FLUENT 3 August 29, 2001 21:46
