Air flow on a pipe
Old   June 2, 2010, 14:51
Default Air flow on a pipe
gulbenkian is on a distinguished road
Hello
I am working on the simulation of a modified melt blowing process in which air flowing through a channel expands forming fibers from a polymer source.
At this moment I want to simulate the velocity flow field from the air flowing on the pipe. I have air coming from a compressor source at 80 psi. The air coming from this source is passed through a 2 mm channel (5 cm length) and then it is expanded to a 3 mm channel (1 cm length) before expanded completely to atmospheric pressure. I use k-e turbulence model and pressure inlet=80psi, and pressure outlet 0 psi boundary conditions. The problem that I have found is that the air speed is too high at the beginning. Usually I have supersonic speeds on the channel and I can get even M=2 on the expansion. These values are very unrealistic compared to what I can see on the lab. Any ideas for what I am doing wrong?. Any help is highly appreciated.
Thanks
gulbenkian is offline   Reply With Quote
Old   June 8, 2010, 07:31
ali
alikami is on a distinguished road
check your ambient pressure if it zero? should be 1 bar or equivqlent...
regards
ali
alikami is offline   Reply With Quote
setup problems - LES pipe flow with cyclic BC (1) and direct mapped inlet (2) florian_krause OpenFOAM 22 June 13, 2013 21:25
stepped pipe flow Tom Cloutier Main CFD Forum 0 April 20, 2003 13:19
Increasing air flow using fans jim sanders FLUENT 0 January 10, 2002 09:24
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 13:19
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 15:00
