GAMBIT and FLUENT turblulent trip
Old   July 8, 2010, 15:08
Default GAMBIT and FLUENT turblulent trip
Oscar
Oskirrii is on a distinguished road
Hello all, I'm trying to model a simple surface trip with a roughness height of .00635 m in my model, but when I export the mesh and read it into FLUENT, FLUENT says the surface isn't referenced by the grid. So it suppresses it from showing/being interact-able. Is there any way to create a surface WITH the wall property for roughness height? I've tried everything I can think of. Surface tool, gridding a 2D surface, expanding the model so that the grid surface is forced to show, etc. Or should I try to separate the two zones? I'm using FLUENT 12, so i thought it would predict transition as soon as I get the meshing right. And the only way I can get the BL tool to display is to have a flat floor surface...otherwise I would just model the trip with a slightly raised surface with a roughness height of .00635m to generate the reference surface I need. Let me know what you think.
Oskirrii is offline   Reply With Quote
Old   July 8, 2010, 15:37
DoHander is on a distinguished road
Probably you can achieve the same thing by defining a certain portion of your solid surface with the desired roughness directly in Fluent (you can specify the height of the roughness if I remember correctly).
Do
DoHander is offline   Reply With Quote
Old   July 8, 2010, 15:39
Oscar
I tried that after it appeared the surface creation tool wouldn't let me do that. The problem too is the entire lower surface is called "floor" and is modeled as a wall. Do I need to split that surface? Will the grid reference them both once I export it to FLUENT?
Old   July 8, 2010, 16:11
Oscar
Ah nevermind, I just figured it out. I used virtual faces and t-junctions with auto-tolerance to merge the separate faces. Everything gridded beautifully now too. Thanks again!
Converting Fluent mesh files to Gambit neutral files samuelkc ANSYS Meshing & Geometry 9 April 21, 2021 06:28
SketchUp 3D model import to Gambit or Fluent Steve Johnson FLUENT 0 February 8, 2009 14:21
Facing Few Problems in Fluent and Gambit Ravi Duggirala FLUENT 5 March 11, 2006 03:13
test cases for Fluent and Gambit Ben FLUENT 1 May 21, 2003 06:44
2D geometry Gambit 2.0.6 to Fluent 6 Bo Jensen FLUENT 1 January 17, 2003 09:55
