Questions on an impeller simulation with Fluent |
April 19, 2000, 05:26 |
1-What is a suitable shape to give to the inlet and to the outlet of the computational domain around the blade?
2-In the compressor case, what are the correct boundary conditions to give? 3-Is it always recommended a great grid-point-density in the boundary layer? 4-To obtain a good convergence history what is the best approach: a) to launch fluent in transient mode, using real BC's and conditions ? or b) to begin the calculations launching fluent in euler steady mode, gradually inserting the viscous fluid condition ? 5- For the impeller blade case, what is better: segregated or coupled (implicit or explicit) ? absolute or relative velocity ? 6- What turbulence model should I use ? 7-To have a rotating grid, what is the correct option: moving reference or moving mesh 8-What is the preferred discretization scheme ? What about the second order discretization for the pressure terms ? any helping hint is appreciated thank in advance Angelo D'Ettore |
May 5, 2000, 13:19 |
Re: Questions on an impeller simulation with Fluent
6- k-eps should be ok 7- mrf gives quicker results... 5- I would begin with the explicit one with absolute velocity
The defaults to starts actually then change one at a time and see the effects on solution... jy (www.reactor-modeling.com) |
July 4, 2010, 10:39 |
Mixing tank
Maryam Amiraftabi
Rep Power: 16 |
please help me, I want to simulate mixing tank by fluent. I define rotating blade as solid, the simulation is 3D, 2 phases without reaction.I want to optimize mixer velocity. the problem is: fluent can not recognize the solid zone and consider water and sand inside of mixer and impeller instead of mixing tank. please help me thanks |
July 7, 2010, 09:33 |
#4 | |
jerry
I uploaded one file. But It can not display. I used internet explorer 8.0. How can I repair? Or some problems happened to IE8? Rgs |
July 7, 2010, 10:08 |
jerry
thanks for your time.
3D Simulation of the Plasma Jet in FLUENT | Steve | FLUENT | 9 | April 20, 2012 06:42 |
Eckardt Impeller flows in Fluent | dibs87jg | FLUENT | 2 | November 2, 2011 06:29 |
Fluent jobs through pbs | ibnkureshi | FLUENT | 5 | June 9, 2011 13:43 |
Why is my fluent simulation giving Cp values above 1??? | wils | Main CFD Forum | 3 | March 26, 2010 09:12 |
Can Fluent start a simulation from a negative time | Ted Chu | FLUENT | 10 | November 26, 2008 21:06 |
