Flow past 2 smooth circular cylinder
Old   July 8, 2010, 18:45
Default Flow past 2 smooth circular cylinder
slip is on a distinguished road
I am trying to simulate the flow past 2 smooth circular cylinder at Re=5.10^5. The diameter of the cylinder is 0.2 m.
I'm using the k-e turbulent model and a transient formulation.
For the specification method I put the turbulent length scale at 0.0225 and the turbulence intensity at 0.8 as recommended in a publication for the flow past one smooth cylinder. (length scale/D=0.0045)
Nevertheless when I look at the results for the Y-velocity, for the vorticity magnitude or the static pressure I don' t see any eddies. It looks like the flow just started to pass over the 2 cylinders. But I launched the simulation up to 200 seconds.
My time step is ok, my mesh is ok, my Y+ are comprised between 30 and 300.
For the solution method I put 2nd order for the momentum, turbulent kinetic energy and turbulent dissipation rate.
That's why I guess there was a problem in the input parameters. I'm going to launch some simulation with a turbulent length scale smaller and see whether it is the problem or not.
I precise that those parameters work with a single circular cylinder.
Could you please give me some advices to help me to understand my mistake ?
Best regards,
Slip
slip is offline   Reply With Quote
Incorrect Drag and Drag Coefficient for flow over a cylinder ozzythewise Main CFD Forum 8 June 13, 2012 06:24
flow past a circular cylinder Senthilkumar Main CFD Forum 2 April 19, 2009 23:18
Tubulent flow past circular cylinder at Re=3900 Jinglei Main CFD Forum 1 September 11, 2007 06:05
Modeling flow acros circular cylinder Zhihua Main CFD Forum 3 April 20, 2004 11:16
Simulation of the Flow past a circular cylinder using STAR-CD M. S. GUEROUACHE Main CFD Forum 0 October 1, 1998 10:51
