Comparison of simulations
Old   July 21, 2010, 05:04
Default Comparison of simulations
Mohsin Mukhtar
Mohsin is on a distinguished road
Hello
I am doing 5 simulations. what i will do is to just change the velocity for every simulation and compare the outcome of the results. But what happens is that if i change the velcoity it takes more iterations to converge and also i have to reduce the convergence criteria.
Do i need to have same iterations, same residual criteria and same under relaxation factors for comparison of my simulations or Is it posisble to give a small change to these parameters as long as the surface integrals and some other convergence criterias are fulfilled?
Thank you for your time.
Mohsin
Mohsin is offline   Reply With Quote
Old   July 21, 2010, 09:16
Chris
Chris D is on a distinguished road
Originally Posted by Mohsin View Post
Hello
No. Iterating and using under relaxation are just a means to an end. They do not influence the solution you eventually obtain, so if your solution is actually converged, then there should be no problem.
Chris D is offline   Reply With Quote
Old   July 22, 2010, 01:43
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
For the same geometry, if you are modifiying the velocity, then you are modifiying also the Reynolds-number. Then you need to modify also turbulence BC (if you are in turbulent domain)
I can imagine that it takes more or less iterations to converge if you perturb the inlet BC.
But your goal is getting a converged solution, that's all.
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
comparison with analytical results (1D)and(3D) CFX Rogerio Fernandes Brito FLUENT 1 December 2, 2012 06:12
Timestepping in two - phase Simulations using RSM challenger85 CFX 0 January 4, 2010 05:00
thread pointer comparison crash in Fluent UDF Miriam Main CFD Forum 0 August 31, 2008 16:40
Comparison of tets and hexs olaf CFX 6 December 18, 2003 16:18
URANS and Transient Simulations bob Main CFD Forum 0 October 1, 2003 03:54
