Boundary condition issue, Modeling flow through spacer filled channel
Old   August 4, 2010, 01:50
Default Boundary condition issue, Modeling flow through spacer filled channel
Asim
asimsaeed is on a distinguished road
Hi
I am new to Fluent and Gambit. I am trying to simulate flow through a Reverse osmosis membrane. There are six faces of the model.To make the model simple (for the time being) I have defined the top and bottom membrane as WALL (no permeation and no slip). The inlet is defined as "velocity inlet" and the outlet ias "pressure outlet".
  • As far as the last two faces are concerend (which are infact parallel to the flow direction) I am unable to finalize what boundary conditions should I define there.
  • Any one who has tackled such sort of geometery, kindly help me in this regard. What model and solver have you choosen for the problem, since the water entering the domain has some amount of NaCl in it also. Should I use Species transport model or Muliphase model (mixture model) or should I combine both,
Awaiting a favourable response.
Regards
ASIM
asimsaeed is offline   Reply With Quote
Fully developed flow boundary condition jits_aps90 OpenFOAM Running, Solving & CFD 9 May 31, 2023 06:17
External,incompressible flow boundary condition? John FLUENT 2 August 19, 2011 00:42
Boundary condition and Poiseuille flow simulation Cyp OpenFOAM 6 March 11, 2011 14:53
Periodic boundary condition & Unsteady flow Somchai FLUENT 2 March 28, 2006 08:51
The initial condition for turbulence channel flow Ma Jianfeng Main CFD Forum 1 April 20, 2005 03:50
