September 17, 2003, 13:43 |
coupled vs segregated solver
Has any one compared these two solvers for the same problem? I am trying to run a case( have run 70 iters so far on a 1 million mesh) and coupled -explicit solver shows me 0 pressure on a monitoring surface, while segregated-explicit solver shows me e6 pressure on the same surface. Is this fine?
sandeep |
September 18, 2003, 02:23 |
Re: coupled vs segregated solver
Hi sandeep,
solver settings are case sensitive, which means that you cannot use both solvers for the same problem. first you have to decide what kind of problem you want to solve and out of that information you choose the solver. coupled solver is for example a good joice if you would like to calculate compressible air flow with supersonic or even hypersonic velocities. seggregated solver is best used for incompressible flow calculations. this two examples should show you the varity of possibilities and therefore its the best to define the problem and to choose the right solver afterwards. mixing both would just confuse you. have a nice day ed |
September 18, 2003, 09:04 |
thanks for the reply, I have a mildly compressible liquid flow with low Re. Which solver would be best in your opinion
September 18, 2003, 10:35 |
from my point of view, I would use the coupled solver.
August 9, 2010, 03:53 |
#5 | |
Sam Mathew
Rep Power: 15 |
Coupled solver energy equation problem | lucioantonio | FLUENT | 0 | April 3, 2009 10:21 |
coupled solver wont work in star ccm+ | richie | Siemens | 5 | November 4, 2008 04:51 |
Convergence Definition of Segregated Solver | Amir | FLUENT | 0 | April 18, 2006 06:21 |
can use coupled solver to calculate combustion | cfdfans | FLUENT | 0 | November 25, 2003 04:48 |
coupled solver / uncoupled solver | Jaan Unger | Main CFD Forum | 0 | September 3, 2002 08:30 |
