August 12, 2010, 09:57 |
have a problem in modeling the freesurfaces?
im trying to model a spillway
have already designed the gambit file but have a problem in fluent seems the water and air are not separated here is a screenshot any ideas? |
August 12, 2010, 10:25 |
by the way
in the boundry conditions screen the velocity inlet that _is for Water flow rate_ the phase is mixture and i dont know how to change it maybe its the reason ! |
August 12, 2010, 16:08 |
john
Rep Power: 15 |
can you clarify what the image represents. i usually view the free surface with a contour plot of volume fraction. |
August 13, 2010, 04:10 |
Thanks for your Reply in here
the first screenshot was Velocity Vectors' now this one : display>contours > contours of phases > water like i mentioned before the problem is , i cannot define water and air however in Gambit , i have created two different velocity inlets for air and water but in fluent ....!?? |
August 13, 2010, 10:30 |
john
Rep Power: 15 |
Try this:
1. create a region (possibly more than one) for the air (Adapt -> Region) 2. initialize your solution 3. Patch the volume fraction for air into the region you created, i.e. set the volume fraction of water to zero (or VF of air to 1.0) 4. run simulation This assumes you've set everything else up correctly (e.g. included gravity, etc.). Fluent has a VOF tutorial modeling a dambreak that may help get you started. Good luck! |
August 14, 2010, 15:58 |
I Appreciate your kind help
that DamBreak tutorial was really useful Last edited by seyedashraf; August 15, 2010 at 05:57. |
A problem with solar still modeling | Amir Khodabandeh | FLUENT | 2 | April 3, 2011 21:55 |
A modeling problem of flow in a tube | Jason | CFX | 0 | July 21, 2004 15:29 |
Problem in modeling solidification | S. Balasubramanyam | CFX | 0 | January 20, 2004 09:54 |
modeling of coupled problem | Godfrey | FLUENT | 4 | May 22, 2002 14:52 |
continue the problem with RSM modeling | cwflying | FLUENT | 3 | April 28, 2002 07:48 |
