Validation of FLUENT
Dear all...
i just run some cases about fluid flow around cylindrical structure.. how can i know my result valid or not? how can i know this FLUENT valid? thank you so much... Gbu |
i do analytical solution for inviscid flow... but from simulation the velocity around the pipe = 0.. but in analytical solution the velocity around pipe = 2*U U = inflow velocity.... i do the simulation based on FLUENT tutorial.... |
i also do an analytical solution for 1 case from FLUENT tutorial,,, when i do comparing,,, the result also give a big difference... especially on the pipe surface.. but when i do comparing above the pipe,,, it gives close result.. is it the limitation of this program? thx all |
Give more information.... and beware of the fact that close to obstacles the velocity lim-s to zero....
1 Attachment(s)
pipe position in middle of frame... i also have problem in pressure also gives a big error (when i comparing to analytical solution) the analytic solution using superposition of uniform flow+doublet equation... here i attach velocity contour produce by fluent for my case |
I do not see velocity problems.... check Re and see the flow pattern.... How did you calculate that velocity must be 2*U?!?!? and where it must be so (around where)?
1 Attachment(s)
where tetha is the angle to the center of pipe.... i calculate them from the superposition of uniform flow+doublet flow... here i attach the picture again with the angle |
On the picture you have resultant velocity ( velocity magnitude) and the formula you are looking for "x"... try to show only velocity on x-axis...
1 Attachment(s)
i also attach the equation here.... thx before |
I am not sure if you can use these equations for all Re range....
mmmmm oke,,, i'll try for smaller Re.... i'll ask u later.... thx for helping |
