September 12, 2007, 23:18 |
regine adapt problem
hi,all,
my model is a cylinder,there are 18440 cells. the z-axis range(0,0.005m).when z-axis range is (0,0.005m)in my region adaption,computer tell me:18440 cells marked for refinement,when z-axis range is(0,0.0025m),there are 18427 cells marked for refinement. WHY are not 9220 of the cells marked for refinement? |
September 13, 2007, 19:55 |
Re: regine adapt problem
what is your criteria for adaption in your case?
Are you trying to adapt based on the gradient of a variable? |
August 30, 2010, 10:46 |
adapt region criteria
Rafael
Hi! When I do a grid adaption using the adapt--> region option, I bound a region of the domain I want to adapt, but, which criteria is applied to adapt the grid?? I mean, will it be devided in a certain number of cells, or is the pressure, velocity, temperature... the parameter taken into account??'
Thanks!!! |
Problem with interFoam; Wave/wiggle alpha1 behavior | JonW | OpenFOAM | 10 | February 4, 2023 07:27 |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
