September 6, 2010, 21:59 |
Parallel Error in ANSYS FLUENT 12
Alex Hon
I always get error message when I using ANSYS FLUENT 12 with a Windows 7 x64 system and ANSYS 12 x64.
unable to read the cmd header on the pmi context, Undefined dynamic error code. 999999 (..\src\mpsystem.c@1149): mpt_read: failed: errno = 10054 999999: mpt_read: error: read failed trying to read 4 bytes: Invalid argument unable to read the cmd header on the pmi context, Undefined dynamic error code. unable to read the cmd header on the pmi context, Undefined dynamic error code. unable to read the cmd header on the pmi context, Undefined dynamic error code. job aborted: rank: node: exit code[: error message] ... The Parallel FLUENT process could not be started. ------------------------------------------- 999999 (..\src\mpsystem.c@1149): mpt_read: failed: errno = 10054 999999: mpt_read: error: read failed trying to read 4 bytes: No such file or directory unable to read the cmd header on the pmi context, Undefined dynamic error code. SuspendThread failed with error 5 for process 2:627A4F0C-CA4B-4435-B90A-4D110B465C35:'D:\ANSYSI~1\v121\v121\fluent\fluent1 2.1.2\win64\3ddp_node\fl_mpi1212.exe -mport 10.10.10.193:10.10.10.193:49174:0 node -mpiw mpich2 -pic ethernet' unable to suspend process. unable to read the cmd header on the pmi context, Undefined dynamic error code. unable to read the cmd header on the pmi context, Undefined dynamic error code. unable to read the cmd header on the pmi context, Undefined dynamic error code. received kill command for a pmi context that doesn't exist: unmatched id = 1 received kill command for a pmi context that doesn't exist: unmatched id = 0 job aborted: rank: node: exit code[: error message] ... The Parallel FLUENT process could not be started. Can anyone help me or provide ideas to fix this problem? Thank you very much~ |
December 20, 2010, 04:31 |
tem
hi ,
did u solve your problem in fluent . I too got the same problem.If u got the solution please help me. my email id :dy-369@163.com thank you! |
December 24, 2010, 05:02 |
Hi Zeusxx,
Have you solved your problem? Actually I have the same problem as yours. If you find the solution, would you please tell me? Thanks. |
January 18, 2011, 08:04 |
NeNaD
Do some PrtScrn (print screen) with your setting up parallel and send me. I can help you only if i see your steps in setup window.
January 18, 2011, 08:47 |
Alex Hon
thank u very much. I solved this problem several months ago. Thank u all the same.
January 26, 2011, 17:34 |
Same error - How did you solve it?
Hello All,
I get the same error only when I run a Composition PDF transport model in the species / transport modelling. Every other model has no problem running in parallel. Can you please tell me how I can solve this problem? |
January 26, 2011, 17:37 |
Screen-shot
Here is a screen shot attached.
March 5, 2011, 08:06 |
Chang Zhixin
Hello All,
I got the same problem when I read mesh file in fluent 6.3, and my PC's Cpu is Inter i7 930 which has 8 processes. if all of 8 processes turned on , this problem would appeard. And if less than 7 processes turned on, it will be no problem. But i don't know why. i think this maybe useful for you. Kevin. C |
March 7, 2011, 19:24 |
Hello Kevin,
I have a Core i7 860 myself and it is the same setup basically. I tried your trick but I was unsuccessful. Let me know what else you had to modify.
Adi. |
March 9, 2011, 07:49 |
Chang Zhixin
Hi,Adi,
Maybe you need to turn off more processers and try again. And i found another route lately, you can setup all options and save case file firstly in single process environment, then iterate it in parallel environment, it will be ok. if still unsccessful, try rebuild your mesh. Kevin.C |
June 27, 2011, 20:11 |
#11 |
August 27, 2011, 07:47 |
#12 |
Tiziano Vaglini
I know this is the fluent forum, and i0m asking about Star-CCM but my problem is the same when i try to start a parallel simulation in Star-CCM 4.04... For Fluent is a problem of the software itself or something related to external program like Mpich? Many Thanks. Tiziano |
June 8, 2012, 10:41 |
possible solution
#13 |
TCH
Regulate up your pagefile as follow:
My computer>properties>advanced>Performance>Configura tion> advanced>modify Regulate up your possible pagefile scale by 1.0~2.0 time size of physical memory |
February 15, 2013, 07:48 |
#14 |
Having the same problem. Reduced number of processors to 4. Not helping! I am using GRI 2.11 mechanism to describe chemistry.
Is it because the CHEMKIN mechanism which fails when used in parallel FLUENT Version 13.0? Akshay |
March 13, 2013, 08:48 |
#15 |
Amjad Farah
Seems to be a problem all around the web but I can't figure out a solution to it. I've got it installed on a number of computers and what I've noticed is that I get this error on AMD processors and Intel ones seem to run fine. Anyone had a similar case?
Error code: 999999 (..\src\mpsystem.c@1149): mpt_read: failed: errno = 10054 999999: mpt_read: error: read failed trying to read 4 bytes: Invalid argument MPI Application rank 0 exited before MPI_Finalize() with status -1073741819 The Parallel FLUENT process could not be started. Amjad |
March 13, 2013, 10:10 |
My solution
#16 |
Alex Hon
I am so sorry that I didn't come back this forum for a long time
Now I post my experience and I hope it can help someone I am not sure whether my experience works well... if you use Win7, try to go to the [Control Panel] --> [Program and function] --> [Open or Close Windows function] under the menu, MAKE SURE you select ALL terms in "Microsoft .NET Framework 3.5.1" then it is OK Maybe the translation I wrote above is not completely correct, because I use a Win7 in Chinese version. but I think you can understand what I mean |
March 13, 2013, 13:45 |
#17 |
Amjad Farah
Thanks for your reply, I tried that and didn't work for me
I tried restarting the computer and still nothing. Maybe it was a slightly different problem that you had. Amjad |
March 13, 2013, 23:54 |
u'd better check UDF
#18 | |
Alex Hon
try to find whether u use codes about UDM or UDS in the UDF, and make sure you open UDM in the DEFINE menu |
March 14, 2013, 10:17 |
#19 |
Amjad Farah
I don't use UDF's, I haven't actually gotten around to open a case.. I just try to read a mesh or a simple case that I prepared on another computer and nothing opens, same error for everything I try to open.
June 18, 2013, 06:29 |
#20 |
hi,
I have the same problem...what did you mean with 'open UDM in the DEFINE menu' because I am using in define_mass_transfer function C_UDMI but it doesnt work in parallel... thanks in advance!!! |
ansys 12, fluent, parallel error |
drag coefficient in ansys fluent 12.0 | krishna | FLUENT | 19 | April 12, 2018 00:49 |
problem of running parallel Fluent on linux cluster | ivanbuz | FLUENT | 15 | September 23, 2017 19:12 |
Fluent v6.3.26 better than Ansys v12.1 | jemyungcha | FLUENT | 2 | August 24, 2012 23:10 |
Fluent parallel license problem | brothershuai | Main CFD Forum | 0 | July 1, 2009 15:41 |
Parallel Fluent with Mandrake | Daniel Dotta | FLUENT | 1 | May 19, 2005 15:30 |
