Inviscid flow on blade does not converge, why?? |
September 8, 2010, 14:49 |
Arash
Rep Power: 16 |
Dear all,
I simulate a stationary blade in inviscid flow but the solution does not converge. the problem is on Continuity residual because it is not going lower than 10e-2. do you have any Idea or suggestion? thanks in advance |
September 10, 2010, 08:53 |
Arash
Rep Power: 16 |
Also I think my mesh Quality is fine enough (Maximum Equiangle Skewness is 0.86) and I used POINTWISE in order to mesh my geometry.
in fluent, I tried all of the numerical scheme such as first order upwind scheme or Quick Sheme .... :-( |
September 14, 2010, 00:43 |
srr
Rep Power: 16 |
All the time I have convergence problems I check the wall y+, it usually shows the cells where the problem exists (where it is really high y+ values), so I introduce a mesh density it that point to improve quality. Your skewness is good, but there might be a problem with aspect ratio, squish, ....
I hope this help you |
Flow meter Design | CD adapco Group Marketing | Siemens | 3 | June 21, 2011 08:33 |
Re: how to do this turbine blade passage flow nanl | manish | Fidelity CFD | 1 | November 2, 2006 23:01 |
Re: how to do this turbine blade passage flow nanl | manish | Phoenics | 1 | February 21, 2006 09:59 |
Boundary Layer created by Euler Solvers | Jim | Main CFD Forum | 31 | November 17, 2001 23:18 |
Velocity Gradients at Inviscid Flow | Lada | FLUENT | 0 | January 15, 2001 07:20 |
