problem during UDF rebuild
Hi there
I want to modify profile.c which was loaded. First, I unload my old udf and tried to build profile.c again but it didn't work with the error message below. ------------------------------------------------------ wrong commend <- first 4 messages are translated in english by myself. file name, directory name or volume labels are wrong. can't find network path 0 files are copied Error: sopenoutputfile: unable to open file for output Error Object: "ntx86\2ddp_host\user_nt.udf" ------------------------------------------------------ How can I rebuild&reload my modified profile.c? |
I had a similar problem but I didn't get that message, what I did was close FLUENT and delete the folder called libudf, and then open again the software and build it again.
I am not sure if this is the answer to your question, anyway I hope this helps. |
That's somewhat different from what I've done till now...
Thanks for sharing your experence. It was helpful for me. =) |
I guess I get an adhoc for this problem
After modifing the UDF, rebuilding as another libudf name(if former libudf was "libudf" then new one would be "libudf_new" or something) can avoid any error occure. I checked this out in linux. I'm not sure that it works at PC but, it may work too. Thanks again |
