UDM (user-defined memory) boundary condition?
I've written a k-w-v2-f turbulence model, where epsilon is stored as a user-defined memory term. I need to set the boundary condition for epsilon at an inlet.
Does anyone know how to set a boundary condition for user-defined memory terms? |
how to clean up fluent working directory history
I also have similar prob for uds bc..expecting
Do you mean UDM BCs? UDS BCs are simple, I can help you with that if you'd like.
For specified flux at outlet (pressure outlet) I am wondering what does specified flux means exactly? and there is one part (even i choose specified flux), i need to fill in the specified value, for one thing it is difficult to know; another thing, I put roughly guessing value there. it turned out 0 and 1 , there is not influence for the result at all. could u give me some hint? thanks! |
The flux is the rate of flow. A specified flux of 0 for a UDS at a wall, for example, would mean that there's no change in the UDS value between the wall and the first cell above the wall. I generally use a specified flux of 0 when I don't know the boundary condition - like at an inlet or outlet.
Thank you a lot! that is very clear
